Camera Error Popping Up
Most of the time when I’m taking a photo on my 4 an error pops up, partially covering the button. I can’t see all of the error, but what I can see is this:- Error:android.hardware.camera2…CamerAaccessException:MA
If I can tap the part if the button that’s still visible the photo takes perfectly.
Anyone got any ideas please?
Hi and welcome to the forum
Be nice to know you are using the default OS and version.
Also do you have an SD card and how is it formatted?
Then have you tried a safe mode, which disables any custom app interference?
Which camera app do you use and have you cleared the cache and storage.
failing all the above are you up to doing a factory reset ?
