Works for me for the moment. Thanks !
Why does FP not respond to this issue? The forum is piled with the problem of the camera module! Please fix it! I had the same problem and I tried all suggestions. Reassemble the module, cleaning the contacts, etc. Nothing helps permanently. Sometimes a little bit of shaking the phone does help. Then the contacts are loose and need to be ‘reset’.
This is a community forum. FP employees don’t usually read along here.
If you have a broken camera module and still have warranty contactsupport to have it fixed/replaced.
