Maybe I’m overlooking something overly obvious, but for the life of me, I cannot find the “C” on the calculator to clear the screen… Anyone?
thanks!
thanks!
You can click DEL to erase single numbers and you can tap = and then 0 to erase all, but you are right, there is no C.
There is a “CLR” function! While typing a calculation, the upper right field shows “DEL”. But after finishing the calculation with “=”, the upper right function changes to “CLR”.
Ok, that may be language specific, I use German. Your “<-” matches my “DEL”. And I suppose that when you enter “=” in the situation above, the sign changes to something that matches my “CLR”.
In the Polish language there is indeed no “DEL”.
555 ÷ 3 = 185 After you tap on the “=” the sign “<-” changes in “CE”.
Tap on the “CE” and your screen is cleared.
Yep, now I get it. I’m not a great fan of this type of ‘hidden features’, but at least now I know how to operate it.
Thanks for helping out!
This topic was automatically closed after 3 days. New replies are no longer allowed.
