Hi!
I encountered a bug which happens when you use data while (national) Roaming is enabled (with GravityBox). I can’t say if this is also the case when Roaming is disabled.
Can I do something to fix this?
I don’t even have these arrows anymore since the switch to Marshmallow.
Yeah, I reactivated them with GravityBox since I think they are very useful… But it doesn’t work properly as you can see
@d2w reported the same issue in be beta forum (here).
But wouldn’t this issue better be raised in the xda forum?
This topic was automatically closed after 182 days. New replies are no longer allowed.
