Bug when using komoot
When i’m using komoot the maps are not shown, there is nothing on the screen.On the google nexus it works.
Have you the fix explained in this topic?:
https://forum.fairphone.com/t/misbehaving-apps-fix-is-being-worked-on-workaround-re-enable-privacy-impact/11721?u=johannes&source_topic_id=14872
Did you already try the following workaround:
Re-enable Privacy Impact by unticking the option found at: Settings > Sound & Notifications > Privacy Impact
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
