Hello Community,
today i did something very stupid, I flashed the bootloader of the Fairphone 2 with the wrong image (bootloader-marlin-8996-012001-1709121620.img from this package https://dl.google.com/dl/android/aosp/marlin-opr3.170623.013-factory-af0b6564.zip of this site http://guideroot.net/fairphone-2-download-android-8-0-o-firmware-nougat/). Now the Phone doesn’t boot properly. It gets stuck at the bootscreen (before any os boots) and starts to heat up. I think that the wrong bootloader causes this problem. Any idea where i can get an original image of the bootloader or another idea how to fix this? Recovery and fastboot still work the battery charges as well, just the system doesn’t boot. I hope you can help.
with kind reguards,
Simon
That’s not so stupid, as the Fairphone 2 is very open to different OSes being easily flashed on it. But to follow through with a tutorial dated April 1st 2017 that sounds too good to be true … well, you felt adventurous I suppose .
If Fastboot mode still works (How did you confirm this?), and it seems you wanted a newer version of Android, why not install LineageOS currently based on Android 7.1 und used by quite a lot of users here? Here’s how …
https://wiki.lineageos.org/devices/FP2/install
Else you could try to manually install Fairphone OS again …
