Since Android 12 update, when I activate my internet hotspot, if none of my bluetooth device are used all bluetooth connections are desactivated.
I am forced to shut the hotspot down, activate the bluetooth device, and use it (f.ex. listenning music with headphones) then reactivate hotspot. If I stop the music, the bluetooth device is desactivated again.
Before the update, it was possible to keep headphones connected (to answer a call for instance) and activate internet hotspot. The device staid connected all time.
I would like to know :
- if someone has had that issue
- if this is a parameter to switch or if it is a android 12 bug
thanks
