Bluetooth connection with FP5
I am trying to connect my Sony earbids with my FP5 and it doesnt seem to want to connect. Any tips?
Can you give more details what you are doing and what exactly does not work?
I am trying to connect via bluetooth and the ear buds do not appear on the list of devices.
Hi @PhilipVI,
which earbuds to you have?
I have the WF-C700N and there is a difference between pairing the first device and other devices. You probably have to reread the manual to be sure if you are doing it right on the earbuds side.
I had problems as well to pair my FP5 due to it being the second device and pairing needs to be initialed via a different process on the earbuds side.
Sony Help (WF-C700N):
https://helpguide.sony.net/mdr/2968/v1/en/contents/TP1000780522.html
I have the WF-1000XM4. I have connected them to another device, previously, but this is switched off
Is there any other BT device connected to your FP5 at the moment?
I have Sony as well and the biggest thing was in the beginning I seemingly forgot to put them in a pairing mode. Afterwards they generally worked flawlessly till a few days ago - they disconnected and I had troubles reconnecting them. I ended repairing them via the app.
It can help to reset the earbuds
This worked. did a factory reset and re-connected. Thank you.
