How can I connect my fairphone 3 with the my corolla 2020 via Bluetooth? The car identify the phone, but the result is that is says that it does not support the phone…
Alex.A
July 20, 2020, 10:04am
#2
Hi there and welcome to the community!
Please check this thread about Ford Sync, where there were problems as well.
My wife has just recently bought an FP3.
Having seen it I am rather keen to buy one too however I tried to connect via Bluetooth to our car’s audio/nav system (Ford SYNC 3). It pairs with the phone but then immediately asks to pair again. The car’s system gives the message that the Fairphone 3 has no SYNC operability.
This is a great pity because I want to be able to connect to the car’s system so that I can call handsfree, use Android Auto (incl Waze) and stream music.
Is there a workaround …
And this post where an answer from a fairphone employee was given.
Hi and welcome to the community!
And if you speak german there is a thread in German as well
Hallo ich bekam Anfang der Woche das FP3. Beim Koppeln des FP3 mit dem SYNC 3-System meines Ford klappte zu nächst alles ohne Probleme.
Allerdings fanden sich Auto und FP3 nicht automatisch beim Einsteigen und Starte des Autos. Also führte ich den üblichen Tipp ‘Entkoppeln’ und ‘Neu koppeln’ aus.
Zunächst sieht alles ok aus. Gerät suchen, PIN vergleichen. Aber nach der Meldung, dass die Kopplung erfolgreich war, meldet SYNC 3 folgenden Fehler: ‘Fairphone 3 bietet keine SYNC-kompatiblen Funkti…
I know it’s not the same car, but there were problems with Skoda as well, and perhaps others.
BertG
July 20, 2020, 10:23am
#3
A working solution - or so it seems - is, to switch the OS to /e/.
But you might want to check the threads on /e/ before switching (just for connecting to the car )
https://forum.fairphone.com/tag/e-eelo
Please try pairing the phone with the car while the phone is connected with the USB charger. I had issues in the beginning to pair when the phone was trying to optimize battery life. Having the phone in “charging” mode, resolved the pairing issue for me. After the initial pairing, you don’t need to keep the phone attached to the charging cable anymore.
system
closed
January 21, 2021, 12:37am
#5
