Hi!
My FP1 started blinking blue (notification LED), I think, after reading some more threads about the issue, it has something to do with an app, but I cant find out which one and how to stop it. Its becoming really annoying. Is there any way I can stop that light from flashing at all and maybe define some signals for specific moments? like, green for SMS, red for low battery? Or do I have to go through every single one of my apps and try to disable notifications to find out which one causes the trouble? I already did that with every messaging app.
I would be happy if someone could help me, that light is driving me crazy!
Facebook uses the blue LED for notifications… do you have that installed?
No I don´t. Neither do I have WhatsApp, which also uses the blue LED. Funny thing though: It stopped! I dont know why and how, but it stopped. So it might have been a bug? IDK. Since I recently made the partition upgrade (which worked perfectly btw), and since then installed a bunch of new apps, one of them might causing the trouble. And decided to stop it again Thanks for your reply nevertheless!
Skype also uses blue linking led for incoming messages notifications
