Ik heb net de gen 6 in gebruik, na jarenlang plezier te hebben gehad van de fp 3. Ik gebruik de telefoon voornamelijk voor mijn werk en kon mooi aan het eind van de maand per contact via de belgeschiedenis het aantal gebelde minuten terugvinden. Deze functie lijkt verdwenen, ik kan alleen zien hoe lang ik de laatste keer heb gebeld. Zie ik iets over het hoofd?
I just got the Gen 6, after years of enjoying the FP3. I mainly use the phone for work and was able to easily find the number of minutes called per contact via the call history at the end of the month. This feature seems to have disappeared; I can only see how long my last call lasted. Am I missing something?
Exactly, you can see when a contact called you, but if you select a contact in the list it brings you to contact details, and details of the most recent call, but not the details of the specific call you selected in the list.
For the record: yes, the 3-dot menu option was in a previous version of the app.
For others interested, using version 188 or later (and maybe earlier), the “Favourites” and “Recent” tabs at the bottom have been combined into one called “Home”. On this tab, just tap on the name (not the icon to the left) and then choose History.
