just updated my phone to 1.5.1 a few days ago and ever since I’m having trouble with the battery. It drains within just a few hours, e.g. unplugged it around 7:30 this morning, it’s down to 11 % now, at 9. Barely used it: alarm, some messages. Restarted it several times, took out the battery… Whatelse can I do?
I’m also confronted with the re-boot-problem, but that’s been going on from the moment I received it But the battery draining is new.
I have a similar problem since the update. After less than four hours, the battery is down to 52% - without using the phone at all. Wifi is on since I’ve been at home all day long. And the report says wifi has used the most of the battery.
… and you are waiting for me to write to you: [quote=“Spielmops, post:2, topic:20754, full:true”]
What do you see, if you go to Settings/Batterie?
[/quote]
before sending a screenshot?
It’s nice of you to answer… I see the wifi has used the most. Yesterday evening, the battery was almost empty. The phone rarely used. The wifi had used 40% being at home all day long. Summarizing all the numbers, I could only find 70%, which was even more strange.
