Hi
After facing a lot of problems in the current version of Fairphone OS (mainly “Process Waiting” errors), I decided to try out the Macadamia 1.9.9-pre3 OTA version.
Despite a few wrinkles, I am quite satisfied with it. Apps run smoothly, no major bugs as such.
But the only issue is the battery status. The phone “charges/discharges” very quickly. While charging, it can jump from 50% to 100% quite rapidly and similarly while discharging. This has led to a slight wariness on my part with respect to believing what the battery shows.
Is there any fix (software/hardware) for this? Is this a problem with Macadamia? If I install some other battery app, will the problem go away?
Regards
Sridhar
