Bad telephone connection
Is it possible that there is something wrong with my FP3, because my phone connection to the mobile network is really bad. With my old Galaxy Note 3 it is even better.
The problem is that mobile connection in the place where I live is weak but with a newer device it should be better than with a very old one I think.
Regards Jan
Which operator do you have and in which country do you live?
KPN Mobile.
Halle, Achterhoek, Netherlands
Could it be that your SIM card is to old and needs a replacement?
Is it possible that a SIM card can be to old?
And there is something else.
Sometimes Iā€™m using a Oneplus 6 with the same card. This phone has a much better mobile reception on my location.
That is also one of the reasons of my question to you.
To be sure I ordered a new SIM card.
Are you able to see what type of network connection you have in Settings > About the phone > Status > SIM card status > Type of mobile network?
Hello Albert,
Thanks for your message.
Mobile network type is LTE.
Signal strength -125 dBm 18 asu
Yes, SIMs deteriorate. Spoke to someone from KPN lately and he confirmed.
Okay, we will see tomorrow when my new SIM arrives
