Hallo
Is it possible to know whether one may select any language? In particular I am interested in Polish version.
Hallo
Yes, there are a lot of languages you can choose from. Polski is one of them.
Thank you! How about a possibility to transfer data from a previous smartphone of Samsung?
Your Samsung phone is likely using Android. Fairphone 3 is using Android.
If you are using Google on your Samsung phone then transferring data should be easy.
