Audiofokus FP5 or older ;-)
Hello everyone,
I have the following error on the stock OS on the FP 5, which has been present on Android for years on other devices. This error drags from one Android version to the next. As far as I can remember, since Android 8. It should not be a mistake by FP. But maybe someone has a solution:
It affects the audio focus:
If I have an app running with text-to-speech (TTS), then sometimes the audio focus works, i.e. when a call comes in or when I press the pause button in the headset to interrupt it, everything works as it should be: When the call is made, the TTS falls silent and when the pause button is pressed on the headset in the same way.
But it can also happen that this is exactly what does not work. When a call is made, the TTS continues to run in the background or the TTS does not stop when the pause button is pressed. As I said, the error only occurs with TTS.
What’s going on? How can this be changed?
