Hi, my application “clavier Android 'AOSP)” stopped. I read on the website that to solve this problem, I had to reinstall the App Store but the button App Store has also disappeared from my phone… Did someone know how to solve this second problem:-)? Thanks.
Assuming that this occurred after you installed an update or the unified storage upgrade, you need to look for the “install Google apps” widget in your app drawer/widget drawer, then drag it onto your homescreen and tap it.
This will install Google apps and fix your keyboard.
