Hello Fairphone 2 users.
First i had the problem with WhatsApp.
I could not send pictures.
This is solved. You go that way: Settings>Sound& notifications>Privacy Impact and push it off.
If you have energy problems, because the battery is empty too quickly the app “avast Battery Saver” helps.
The camera sound is bad: Z Camera is a good camera App without sound.
Fast and quick PDF-reader: Foxit PDF
Second i have a Problem with the app: DAVdroid.
I want to synchronize my posteo.de account. But i cant. Is there a friend with an solition ?
I just checked out Camera MX and it doesn’t make the shutter sound when taking a photo or a video, only a very quiet beep when stopping the recording of a video. Also it doesn’t require nearly as many permissions as Z Camera. So if you value your privacy and data on your phone, you know what I’d recommend…
Hi @Betaloleyx!
Are you still having Problems? I can say that syncing both contacts and calendars using DAVdroid and posteo.de works perfectly fine for me.
cheers!
