- That battery voltage is fine. 4.27 about 90% charged.
- There are two white squares and both on the core module
How âwaterproofâ is the FP3? IP Rating - #32 by anon9989719
The one you see is on the core module, is the one on the left of the image above
As far as replacing the bottom module. Iâm not sure but the with a good battery Iâm sure the phone would start without the bottom module. After all failures of the bottom module happen and people worry about the battery going flat before they can replace it.
So thereâs no fairphoneangel you can ask for assistance ?
