Android13 "Try saying"
I have updated my FP4 to Android13. Now when I try to turn off the phone, a screen with mic symbol appears asking me to “Try saying” some phrase. I can find no way of deleting or bypassing this screen, so I can’t generate the usual 4-option “leaving” screen - very annoying. Any comments/ suggestions?
Open Settings, then go to Gestures. In Press & hold power button, you can choose if you want to open Google assistant (what is defined now on your phone) or if you want to open the power menu.
Alternatively, you can swipe from the top twice and find a power button on the screen in the bottom right.
Very many thanks - problem solved!
Again, many thanks for this second option.
Danke für diesen Tipp!! :sunglasses:
