Android KeyStore broken - when the device was unlocked with Face unlock
Hi!
I am a developer working on apps that needs to store keys in Android KeyStore. Unfortunately something seem to be broken in the Fairphone 5 and 6 (and potentially other Fairphones) KeyStore/Biometric API implementation as trying to access keys that require an unlocked device to access result in a UserNotAuthenticatedException when the device was unlocked with Face unlock, a non-strong biometric method. This used to be a bug in Android but accordingly to Google’s official documentation, but it should be solved in Android 15: https://developer.android.com/reference/android/security/keystore/KeyGenParameterSpec.Builder#setUnlockedDeviceRequired(boolean)
I could reproduce it on a Fairphone 6 running Android 15 and then updated to Android 16 as well as with a Fairphone 5 running Android 15.
Google confirmed that the device incorrectly passes a parameter indicating that a non-strong biometric is enabled to Android, see the issue on Google’s Issue Tracker: <https://issuetracker.google.com/issues/506989112>
I wanted to raise awareness of the issue and I hope someone can help getting to the bottom of it as it might be in Fairphone’s as an OEM’s implementation and can affect many-many apps, resulting broken authentication and/or encryption or just various broken functionality (imagine an app storing keys related to secure API communication this way).
It would be helpful if you would pass this to Fairphone.
Already did, just I’m not sure whether there is a more developer-centric issue tracker than the public-facing support page which is clearly meant for regular customers: https://support.fairphone.com/
So I also want to raise awareness, hopefully increasing the possibility so it will be picked up. But if anyone knows a better way to let Fairphone developers know, please tell me! Thanks a lot!
There is no direct way to development, it has to go through support.
