I bought a Fairphone 6 with murena to test the OS but the change was to much for me so I decided to install Android instead.
I followed every steps from this guide https://support.fairphone.com/hc/en-us/articles/18896094650513-How-to-manually-install-Android-on-your-Fairphone
My phone is correctly unlock and when I use the .bat script my phone is detected. But the script keep crashing when flashing some partitions. Not always on the same partition. The error message tells me to remove the battery and restart bootloader with the volume down button.
I tried to unplug and replug the battery multiple times and each time the script crashes at a different step and not always a further one than previously…
What can I do to finish this installation once and for all ?
