Great Android 6 is coming to the FP2.
First of all thanks to the team for making this happen!
I would like to take the big update as an opportunity to wipe my phone clean to get rid of all the junk I’ve been gathering over the last 14 months. The phone has started to become slower recently.
Anyone’s got some advice how to do this best:
First install the update, then perform a factory reset?
First do the reset, then install the update?
Somehow wipe the phone and install the full Android 6 from scratch (instead of an upgrade installation)? Is that possible? How?
It seems that it is NOT mandatory to do a factory reset to update 5.1->6 (which would be clear the user data partition) - it is discussed here and was not mentioned in the 3 strategies here above.
