Current version Android 16 release 3 QPR1 security patch September 2025
Status
It works on my FP3+ ™. Use at your own risk.
You can report issues here Issues · danielzhang130/aosp_changes · GitHub , but I’m not going to guarantee a reply.
Download link
Screenshots
Features working
minimal set of included apps
built in gapps
SD card
Nova launcher prime
Material You theme picker
Bluetooth
Nearby share
Calling
Duo sim
Fingerprint sensor
No browser forced on you, install your favorite
Not rooted
Features not working
Please report issues by creating an issue on Issues · danielzhang130/aosp_changes · GitHub
Flash instructions
backup your data and unlock bootloader (see Fairphone support site for unlock code)
boot into fastboot (turn phone off, hold down vol-down and plug in usb cable)
wipe data with
fastboot -wYOUR DATA IS NOW GONE -
download and unzip image
flash images with
fastboot flash system system.img
fastboot flash --disable-verity --disable-verification vbmeta vbmeta.img
reboot
fastboot rebboot -
good luck!
Build instructions (for experienced users only)
clone aosp release
apply TrebleDroid patch from https://github.com/danielzhang130/aosp_changes/releases/download/android-16.0.0_r3/patches_for_devs.zip patches-for-developers.zip using treble_experimentations/apply-patches.sh at master · TrebleDroid/treble_experimentations · GitHub
apply custom patch (android-16 branch) from GitHub - danielzhang130/aosp_changes: Changes to aosp, generated with https://github.com/danielzhang130/aosp_patch using GitHub - danielzhang130/aosp_patch: Save changes to aosp repo managed git repositories as patches
build with
m dist -
Sign your build (https://source.android.com/docs/core/ota/sign_builds)
