I want to try ubuntu touch on my FP5, so I need to downgrade from Android 14 (pre-installed) to Android 13.
I have successfully followed the instructions on the FP page for unlocking the bootloader etc (https://support.fairphone.com/hc/en-us/articles/18896094650513-How-to-manually-install-Android-on-your-Fairphone)
I downloaded the zip file, unzipped it and ran the script. It detects the phone and asks if I am sure I want to continue. I say yes, It then does nothing.
Here is the output from the terminal.
❯ ./flash_fp5_factory.sh
*** Fairphone 5 flashing script ***
INFO: The procedure will start soon. Please wait...
INFO: The package type is "user-factory"
INFO: You are using a Linux distribution.
INFO: Validating the integrity of the package.
This might take a while. Please wait...
INFO: Validation complete.
WARNING: Flashing this image wipes all user data and settings on the phone.
It will also remove the Google factory reset protection.
Are you sure you want to continue?
Type "Yes" (case sensitive) and press enter to continue: Yes
INFO: Looking for connected device(s)...
INFO: One Fairphone 5 in fastboot mode found (serial number: xxxxxx).
I don’t really know what I should have done differently.
