Android 12 - Clock on Lockscreen
Seems I’m just visually impaired.
The reason your clock on the lock screen is smaller than mine is because of the two notifications. If you swipe those away it goes back to being huge.
Yes probably. See my post above #16. One of those notifications is permanent so the clock is always a reasonable size …
Just for the records: Thats fixed with the Android 13 update, you can now select if you want the clock in 2 lines
Settings-display-lock screen
