Hey there,
is a Huawei Quick Charge charger compatible with the Fairphone 3?
The charger model is: HW-090200EH0
Input: 100-240V 50/60Hz, 0.5A
Output: 5V - 2A or 9V - 2A
Thanks a lot in advance!
Isi
Hey there,
Isi
Can’t test, but it seems perfectly compatible to me. I can assert it works on FP2 though, so it should have no problem to work on FP3 (and QuickCharge should work as well).
Official specs:
I would not use it on 9V though.
You don’t choose the voltage, it is negotiated between the phone and the charger by QuickCharge. Connecting such a charger is harmless as 5V is the default unless something else can be negotiated.
Thanks for the quick answers!
