The agenda widget works well, however if I try to open an item from it (or to lunch the app from the global list), it crashes before anything is displayed.
Has anyone the same problem or found a fix/workaround? Thanks!
Which LineageOS build are you on?
(Settings - About phone - tap on Android version - LineageOS version)
Since LOS 17 I use Simple Calendar Pro … The default agenda has lost too many features
https://f-droid.org/app/com.simplemobiletools.calendar.pro
I’m on the last Lineage 17.1 build (2020 04 22)
Seems there was work going on concerning the calendar since then … perhaps it’s fixed in the next build … https://www.lineageoslog.com/17.1/FP2.
The first build since last month has been published. Now I can open the calendar from the application list, but I don’t have the widget anymore.
Let’s hope it will be re-added soon…
I dug a bit about the new calendar app. So, Etar isn’t a LOS specific app, it’s a generic one which could be found on github.
This page has a link to the Todo Agenda app on f-droid, which is outdated and speaks about another todo agenda app for more recent android version but the link has no href
. However, putting the provided string in the URL works: https://f-droid.org/en/packages/org.andstatus.todoagenda/.
I installed this app and now I have a widget again.
I’m putting it here as it’s not straight forward at all. It could eventually helps someone.
