After installing Android 15 I cannot listen to the radio by my hearingaids. How can I tackle that issue?
8 posts were split to a new topic: Nana upgrade naar Android 15 werken mijn hoortoestellen niet meer met de Fairphone 4
Got the same problem. This didn’t solve it, unfortunately.
The following is proably no solution, but you only know when you try.
Did you try to delete your hearing aids in the Bluetooth settings? Delete the app from your hearing aid provider.
Restart your phone and set up your hearing aids again.
From which manufacturer are your hearing aids?
Unfortunately I already did that, to no avail.
It’s a Signia Pure Charge&Go AX. I only use one, for the left ear.
Have you already asked your hearing care professional or Signia customer service?
