by charging / after plug in the power pack, each time the Fairphone turns on. Is it possible to disable this behavior?
thanks!
webaschtl
thanks!
webaschtl
This is not usual behavior.
What you’d expect is to see the black screen with the white Fairphone logo - as though the FP was starting - but then - if you don’t press the power button - it should show the charging animation for some time and then turn the screen off again.
A few people have described this behavior while trying to do the battery reset which then failed, because the deep-discharged battery didn’t charge faster than booting discharged it.
I never heard of this in a different situation so I’d guess it has to do with your power pack.
