@DjDas has the same problem:
It seems that Add to calendar has stopped working. It worked before and I can’t find a reason why it shouldn’t work anymore. Could you please verify?
Steps to reproduce:
- Install “Add to Calendar” (1.0 or 1.1 Neither works)
- Download an .ics-file, for example from that page: http://kalender.kjwien.at (You have to press the little calender icon next to an entry).
- Open it and select “Add to calendar” from the window that opens.
- Nothing happens (the calendar should open, with the option to save the new calendar entry. This has worked before.)
PS: I’m trying this on Fennec F-Droid (Firefox Mobile) 39.xx. The browser seems a bit unresponsive after trying the import.
Here is my log:
[quote]08-05 13:10:17.864 I/ActivityManager(514): START u0 {act=android.intent.action.VIEW dat=file:///storage/emulated/0/Download/download(18).ics typ=text/calendar flg=0x3000000 cmp=org.dgtale.icsimport/.MainActivity} from pid 4388
08-05 13:10:17.960 W/System.err(3669): at org.dgtale.icsimport.MainActivity.onCreate(MainActivity.java:53)
08-05 13:14:03.354 I/ActivityManager(514): START u0 {act=android.intent.action.VIEW dat=file:///storage/emulated/0/Download/download(18).ics typ=text/calendar cmp=android/com.android.internal.app.ResolverActivity} from pid 6648
08-05 13:14:04.376 I/ActivityManager(514): START u0 {act=android.intent.action.VIEW dat=file:///storage/emulated/0/Download/download(18).ics typ=text/calendar flg=0x3000000 cmp=org.dgtale.icsimport/.MainActivity} from pid 4388
08-05 13:14:04.485 W/System.err(3669): at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:148)
08-05 13:14:04.485 W/System.err(3669): at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:210)
08-05 13:14:04.485 W/System.err(3669): at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:191)
08-05 13:14:04.485 W/System.err(3669): at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:179)
08-05 13:14:04.487 W/System.err(3669): at net.fortuna.ical4j.data.CalendarBuilder$ContentHandlerImpl.startProperty(CalendarBuilder.java:346)
08-05 13:14:04.487 W/System.err(3669): at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.parse(CalendarParserImpl.java:211)
08-05 13:14:04.487 W/System.err(3669): at net.fortuna.ical4j.data.CalendarParserImpl$PropertyParser.access$1(CalendarParserImpl.java:200)
08-05 13:14:04.487 W/System.err(3669): at net.fortuna.ical4j.data.CalendarParserImpl$PropertyListParser.parse(CalendarParserImpl.java:178)
08-05 13:14:04.487 W/System.err(3669): at net.fortuna.ical4j.data.CalendarParserImpl$ComponentParser.parse(CalendarParserImpl.java:390)
08-05 13:14:04.487 W/System.err(3669): at net.fortuna.ical4j.data.CalendarParserImpl$ComponentParser.access$1(CalendarParserImpl.java:376)
08-05 13:14:04.487 W/System.err(3669): at net.fortuna.ical4j.data.CalendarParserImpl$PropertyListParser.parse(CalendarParserImpl.java:175)
08-05 13:14:04.488 W/System.err(3669): at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:125)[/quote]
PS: I found this bug report on Github, which seems to deal with the same problem. Unfortunately the developer does not have access to an Android 4.2.2 phone.
