I have an urgent problem. Managed to activate my screen lock without having making one,something that means that I can’t get into my phone anymore. I have tried different numbers, but since it looks like the code can contains endless numbers my while guessing of numbers are useless… And I have to waite 30 sec after evry 5th attempt. Anyone in here knowing how this can be solved ? Can this be reset without knowing the code ?
If you have the Android Device Manager enabled, there seems to be a quite easy solution: http://trendblog.net/how-to-bypass-android-phone-lock-screen-pattern-pin-password/
If not, do a web search, there seem to be some other approaches, but since I haven’t had this problem myself, I can’t give you any recomendation.
