Has anybody managed to use a USB adapter to read and write files on a pen drive to and from their Fairphone 3? I’m thinking of doing so
Yes. Doing that every now and then for making backups. Using standard USB sticks with USB-C adapter. Works plug and play.
Sebastian.
Grand Just ordered myself one
USB-drive with four connector types, does work with the FP3 (and also has a FP2 connector):
Yup I even used my USB3 1TB SSD with a OTG adapter… no Problems
Okay one Problem… The Battery is draining FAST… as in 1% per Minute
I use the ’ Volutz USB C OTG’ Adapter
