A15 upgrade status/BT settings
I upgraded to Android 15 yesterday.
On A13, I could only send or receive phone calls within about 10 seconds after reboot, when roaming, due to issues at my network provider.
These issues have disappeared, since I upgraded to aandroid 15 :slight_smile:
I have not encountered any issues since the upgrade.
One change that’s annoying tho, is that now I have to do 2 steps to enable BT, first open the dialog, then slide BT to on… on A13 BT would be turned on, with a short-press… Anyone got an idea on how to get the old behaviour back, for BT enable/disable ?
If you have root, you could try https://play.google.com/store/apps/details?id=be.casperverswijvelt.unifiedinternetqs
The problem is caused by Google that chnaged the tile behaviour with Android 14 or 15.
And frankly I fail to understand why, since it was possible to get to detailed settings if you needed them, just by long-touching the tile. Now we have to do three touches instead of one, just to turn on or off …
I agree, It’s just sooo annoying. I have to use it every day and every day I ask myself several times, who in the right mind would come up with such uncalled for enshittification.
