Does anyone know which colours are possible with the Fairphone’s LED? It seems that not all colours are supported, e.g. violet.
I’ve been able to set up green, red, dark blue, light blue, and a strange white that’s like all colours at the same time.
I’m adding @Jacky and @humorkritik to discuss the light notifications here.
What I found is that if you choose a colour, which the FP’s LED can’t show, it turns out red.
I think @Stefan is right, and I noticed the same about violet. I didn’t even manage to get different shades of blue, and I vaguely remember that when I tried white, I also ended up with red again. However, red, blue and green were more or less ok for me.
@Roser_Blasco, could you post the hex codes for the colours you achieved? (If you used GravityBox, that should be easy: you can see the hex code in the colour picker).
I my case, something is at odds with the hex codes: #f00ffa2 gives me a green - and #ff009bff also gives me a green . WTF?
A lot of other settings, like yellow colours etc., also don’t translate to any of the LEDs actual colours. Currently, it’s guesswork how I can achieve something else then green and red . I had blue, once, but after a reset I had to change my settings again. Now, blue is gone.
Blue should be #0000ff
(I was just trying this out with LED Color Tester).
I also cannot achieve the following…:
You can find a follow-up discussion here:
